Win a £4,305 BagSport Turbo Kit — Classic Mini DIY Raffle
We're excited to announce our latest raffle — and this one's a big one. We've partnered with BagSport Fabrication to raffle off their brand-new 2026 Rear-Mounted A-Series Turbo Kit, the complete intercooled package worth £4,305.
If you've been eyeing up a turbo build for your Mini, this is your shot at the best kit on the market for a fraction of the price.
What You Could Win
BagSport's rear-mount turbo kit is their flagship A-Series package for 2026. It's designed with performance, build quality, and under-bonnet aesthetics in mind — and requires zero body modifications. This is a true bolt-on turbo setup.
The complete intercooled kit includes:
  • 3D printed 316 stainless steel manifold and downpipe package
  • 3D printed alloy inlet manifold with integrated wastegate actuator mounting
  • Alloy front-mount intercooler with 3D printed end tanks
  • Your choice of turbocharger — Garrett GBC17-20 (journal bearing) or Pulsar 3942G (dual ceramic ball bearing, brings boost in ~500 rpm sooner)
  • K&N air filter with ABS intake pipe
  • Forge Motorsport dual-piston blow-off valve
  • Both charge pipes (turbo to intercooler and intercooler to plenum/throttle body)
  • Plenum chamber (carb kits only)
  • AN4 oil feed line and tee piece
  • Oil drain fittings and hose
  • All required gaskets, fasteners, silicone couplers, and clamps
  • BagSport t-shirt and paint stencil
Suitable for standard engines on low boost settings, and fully capable of over 200hp on a built engine and gearbox.
How It Works
This raffle is hosted on Raffall. Tickets are £6 each and we've limited it to 1,500 tickets total. Once they're sold, no more will be added.
The raffle closes on 30 September 2026 at 20:11. The winner will coordinate directly with BagSport Fabrication to choose their turbo and carb/EFI configuration, and arrange delivery.
UK and international entries are welcome. Shipping is included for the winner.
Why We're Doing This
Every ticket supports Classic Mini DIY — the content, the videos, and future raffles. The more support we get on these, the more we can do. Simple as that.
Good luck to everyone who enters. We'll be posting updates as tickets sell, so follow along on our socials if you want to keep track.
